Add more pictures please. Top of piston and the combustion chamber. Do you know what the piston to cylinder wall clearance was? Did you allow the engine temp to get to operating temp before pushing it hard?
My first guess here is the piston ring stuck during the breakin process. This caused poor compression and incomplete burn (all the oil/fuel not burning and passing through the exhaust). Looks like a cold seize after that. Piston to cylinder wall clearance may have been too tight to start with.
Piston to cylinder wall clearance 0.10mm. After run in must be 0.11/0.12mm. Yes, first I warm up engine. Its my fault, I wrong carb adjusting. The grinding of the cylinder and the fitting of the piston were performed by a very good engineer from Poland. After rebuild, exhaust have the same oil leaks. Before engine stuck, he runing 2.3mth
My opinion is that 0.10mm (.0039") is too tight. Iād say 0.14mm (.0055") minimum would be better.
I know this is more than suggested in the owners manual.
Again, this is my opinion and others may vary.
@Christian_Fox @Rapid1
Yes, .10 is way too tight. You want a minimum of at least .13mm
How about those oil leaks? Has anyone from the forum had a Leopard, or has anyone seen what it looks like in kart other people?
It leaks on stand to, and makes a lot of smoke.
I set carb with jetting app. This foto is after engine run in procedure.
@wsalisbury3 @tjkoyen @KartingIsLife @GregF ???
I am asking about it, maybe I have some other fault? Although everything is after the service, there should be no problems. On Youtube, I see movies with this engine, no one is smoking that much. Nobody has such oil leaks, even when the kart is in the stand.
Honestly the amount of oil is not unusual for an a Leopard or similar (racing) two stroke thatās being operated below itās correct RPM for a long time, or not being driven very hard. Smoke on the stand is not unusual either. Since youāve confirmed your popoff is holding itās probably not getting a bunch of fuel.
Iād be more worried if there was no smoke. At lower RPM a lot more of the fuel and oil escapes out the exhaust and leaves oil deposits. Also, if they engine is not being used hard and has longer times off full throttle, the oil accumulates in the crankcase and is then expelled when power is added again.
To seal it, usually wrapping the flex part between the header/manifold and the pipe will reduce the leaking at that point. Securing the exhaust wrap with safety wire can help it stay in place.
Come to think of it, it might be worth checking the flex for cracks.
0.10mm is going to take a long time to break in I think, pretty tight for an iron bore. Is the builder familiar with the leopard in particular? If they are, then they should understand the difference between the dot colors on IAME pistons. This chart is worth reviewingā¦
While weāre here, hereās the Leopard Owners Manual
MY09-Assembly-Manual.pdf (3.4 MB)
Agree with James, itās a lot of oil, but impossible to say if itās too much since youāre never getting the engine up to racing speed and RPM. Lots of 2-stroke engines will load up and be really rich on the bottom end if they never get a chance to rev and clear out.
I have Tag engine. Not RL, but carb jetting is similar. This is manual for my engine. leopardmanual2003.pdf (3.2 MB)
Both models are TaG (Touch and Go, ie electric start), you have whatās sometimes called the pre-09 leopard. They are very very similar.
One thing to note, and you may already be aware⦠but jetting recommendations are based on a specific oil ratio (and popff). The manual recommends 6% oil and you mentioned youāre on on 5%. Something to keep in mind as you begin to tune the engine for performance as currently it will run rich on the fuel side for a respective jet position.
My '09 Leopard spits a lot of oil also if I run it on the stand too long and then smokes on the grid waiting to go out. Generally I only try to warm it up a little on the stand until water temp comes up to 95 F or 100 F then take it easy on my out lap until water temp hits at least 105 F. If you have cooler weather, you can cover the radiator with rows of tape and peel them off as needed to regulate temps.
Like James said, you may need more break in time.
Are you suggesting me make a 6% fuel mix? I have a pop off of 10.5psi.
I donāt think I fully understand you.
10.5psi is good.
I would recommend going with 6% to isolate that variable. The downside is that all of this is based on the kart being run in a racing situation.
Also depends on what oil you are using. Full Synthetic can probably take 5% but especially during break in, error on the side of caution. Remember as thing heat up, they expand at different rates. The Iron Cylinder will expand slower then the piston and you risk Seizure with smaller tolerances. By going to 6% oil ratio you are adding protection. After my last Top End rebuild, I took it slow, building a lot of heat in the cylinder by taping the radiator, gradually building up RPM and letting it cool between sessions. It is possible you did not allow enough time before pushing the engine for everything to seat properly. Do not worry about the oil spitting from the pipe during this time. After a thorough break in, the oil spitting should get better. Best done on track, where toward the end you can fully open throttle.
I mentioned the oil previously Mike, even just to discount that variable Iād run it with spec oil (one that contains castor oil as per IAME recommendation)
The stuff youāre using Motul Kart GP doesnāt contain castor oil.
This is just my thoughts by the way, Iām not familiar with the Leopard but I am an engineer - airplanes, we donāt do anything technically that isnāt by the book and that translates into pretty much everything I do in life
, others will chime in Iām sure if that oil is fine to use
I can buy Shell Advance Racing M oil. Only this oil is available, it can be ordered. Motul Kart is praised by everyone, applied to a variety of engines.
Yes Iām sure it is, but I wouldnāt be concerned about itās use in a variety of engines, Iād only be concerned to know if other people with exactly the same engine as you have use it without issues.
Mobil Jet II is used in a wide variety of airplane engines, if the technical documentation of the particular plane Iām working says use something else, Iāll use something else. If I donāt have something else, Iāll ground the plane.
ā Smoky emissions from two-stroke gasoline engines (2T) are a problem for the environment. Use of vegetable oil (oxygenate) is one solution. A biodegradable 2T-oil was developed from castor oil, which consisted of tolyl monoesters and performance additives but no miscibility-solvent. Evaluation revealed that on one hand it reduced smoke by 50ā70% at 1% oil fuel ratio and on the other hand it was at par with standard product specification.ā
Iād order a couple of quarts of the shell racing m, if only to rule out that as a variable.
Iām pretty sure the root cause is low RPM operation as mentioned by others, but the oil spec may well be exacerbating it.
Thanks for the clarification. Should the Shell oil be mixed according to the 6% instructions? Or is the 5% a good ratio, not too little and not too much?
It turns out that Racing M is not available. . There is only VSX and Ultra. But I will still be looking.
I tried to reduce variables and now weāre adding more
For simplicity, stick with the 6% per the manual. The reason I say this is because of the effect the oil content has on jetting. Change the oil ratio and the base settings are no longer valid. Itās less of a too much/too little oil matter and more of a baseline thing.
Ideally use castor based oil per the manual, but above all stay at 6% no matter what type unless you build a relationship with an engine builder locally who specifies otherwise and also can help with carb setup.
