Instead of just accumulating seat time, I encourage you to really dig into the experience to learn as much as you can. That is, when you make a mistake, crash, and hit the reset button to try again, then before you head back on track, also hit the reset button in your head, and try to diagnose exactly why you crashed (the cause/effect relationships that resulted in your destruction
). Think about the four stages of crashing:
- Oops
- Uh Oh
- Oh S***
- Aw F***
Ask yourself if you ‘felt’, something around stage 1 or 2, that you ignored, and might have allowed you to avoid the crash if you had taken action then. Or, if you didn’t recognize what was happening at the time, think back and see if you can pick out the ‘signals’ from your memory of the experience that indicated you were in trouble.
Also, I’m not sure if KK provides ‘data’, but if so, use that to try and identify opportunities for improvement.
For example, I’ve been chasing an alien’s time at Long Beach in iRacing. There was one turn that I was 0.15 off the pace, and struggling with the car snap oversteering (and scrubbing speed) at the exit of the turn. Looking at the data, I could see I was turning in a little early (so taking a slightly shallow entry), which was causing the major part of rotation for the turn to shift from around the apex to the exit of the turn, which was causing the outside rear tire to ‘overload’ when I tried to accelerate hard (that’s my cause effect analysis).
You could stop at this point (once you’ve identified the ‘issue’), and you will likely be able to improve your performance. However, if you take it a step further, and try to understand WHY you are making a mistake or sub-optimal choice, then you can really leverage the information/experience/lesson that you have.
For example, regarding my previous example, even though I’m not sure exactly why I was turning in early, mentally digging into it…
(it think it was a combination of not trusting the front end on the way in, not wanting to turn later and built too much rotational momentum early in the turn-because the car is very ‘snappy’, and maybe a dash of that’s my default ‘style’)
…gives me perspective, and things to consider when working out how to actually ‘fix’ the issue.
In the case of this example, I used imagery to prepare, and then used my understanding of the problem to simply ‘force’ myself to change my turn in timing/technique until it was established as a habit. The new habit I created fixed the snap oversteer and put me on pace with the alien through that turn.
