Hi Guys,
I have a CRG Road Rebel KZ… just tried my Sniper alignment today…. Got the toe set …. But I can’t set the ‘sweep’ to even the Ackerman.
The lasers are too low to get a reading on the ruler.
I raised the front ride height, which drops the spindles… that’s. my only guess….anyone else have this problem ? Any solutions ??
Thanks,
Bill
CrocIndy
(Matthew Burpo)
April 11, 2024, 1:57am
2
Use a tape measure off a consistent point on the chassis. I pull the tank and use the upright.
Sweep can be a bit of a pain sometimes, there might be a nugget in there that can help in addition to what Matthew said:
I was doing a front alignment on my OTK to increase some negative camber and noticed that the total distance of each tie rod was off by a bit, ~32cm vs ~31.5cm… this lead me to check the sweep and its off as I would expect with the tie rod difference.
Went straight back to the drawing board to reset everything…
Did a runout test on the kingpins, tie-rods and they are true (visually steering rod is straight). Set the steering wheel straight by measuring bar stock level on setting column. Set to…
For the first time I notice something strange with my kart steering. Currently I have it on a vertical stand with no wheels (winter storage) and as I look at it, I noticed that when I turn the steering, lets say to the left or simulating a left turn, the steering will sweep to the left, the left and right spindles will move accordingly, but as I get to almost lock up, the right spindle (outside for a left turn) starts to drops/sweeps back to the right (opposite to the turn)?
This is on a Margay…
Numbah26
(Mark Chandler)
April 11, 2024, 2:08pm
4
I saw someone with a Birel have to do this too.
