Gearing Calculator Sheets for Shifter Kart Engines
Over time I’ve made these for my own use (Adapted from John Denman’s original CR125/CR80)
Use these to calculate various things such as top speed for a given gearing/RPM, RPM drop between gears and more. Make sure you update the RPM range for your specific engine\tune and verify the tire circumference for best results.
Gearcalc
They are mostly older models (Figures since I made them around 2013 ish), but I did add the SSE 175 and RoK recently.
CRS Shifter Kart Gearing Calculator.xls (66.5 KB)
Debei Motori Spike24 Shifter Kart Gearing Calculator.xls (41.5 KB)
Honda CR125 & CR80 Shifter Kart Gearing Calculator.xls (42.5 KB)
Honda CR250 Shifter Kart Gearing Calculator.xls (37.5 KB)
IAME SSE 175cc Shifter Kart Gearing Calculator.xls (30 KB)
Maxter MXV & MXO Shifter Kart Gearing Calculator .xls (163 KB)
MC Motori BAT 3 Shifter Kart Gearing Calculator.xls (37 KB)
TM K9A, K9B, K9C, KZ10, KZ10B Shifter Kart Gearing Calculator.xls (37 KB)
Motori Seven L3 AT Shifter Kart Gearing Calculator.xls (37 KB)
Pavesi Evo2 25deg Shifter Kart Gearing Calculator.xls (37 KB)
SGM SL204, GA207, GA210, GA211, L198 Rotary, F196 Rotary - Shifter Kart Gearing Calculator.xls (73 KB)
Vortex RVXx Shifter Kart Gearing Calculator.xls (37 KB)
Yamaha YZ250 Shifter Kart Gearing Calculator.xls (37.5 KB)
Vortex RoK Shifter Kart Gearing Calculator.xls (37 KB)
Vortex RVS Shifter Kart Gearing Calculator.xls (37 KB)
You can find Google Sheets versions here:
https://drive.google.com/drive/folders/1-lm7KOmb0fU28lXLMEIPnTAP41FznIad?usp=sharing
